Vielen Dank!
Kaufberatung BMW 225xe iPerformance
Thanks for the advices earlier. Driving around my 225xe and its enjoyable ride. 18k km (EZ 12/2018 for 19500Euro with all season tire) + premium selection 2 years Few things I should have explored more or asked before buying (or dealer should have mentioned):
1. Battery size (Mine is 7.7 hence around 32km in weather these days covers my 2 trips to work easily) Bigger would have been better.
2. Its has sport seats step tronic cruise control (lane assist would have been nice but i believe its extra $)
3. It DOESN "T have retractable mirrors : huh:I really miss this feature in daily use when I have to park on street . X /(Is it possible to have them installed later?)
4. Some videos I saw the doors have ambient light strip but mine doesn't have those. Are those in extra package as well or self installed?
5. My model could get E-number plate? (Already have normal number plate now Could not speak much German and did not ask at the office) : /
6. Speed limits in Navi would have been nice. (I believe they are also in drive assist package $)
Overall as a family we are satisfied with the first purchase and personally I feel I should have done more research (few minor things above). Mostly driving around in Eco-pro mode. Any additional tips are welcome. Thanks
Congrats and enjoy
Congrats and enjoy
Thanks. Do you have something to say about 3 & 5th?
#1 The bigger 10kw battery was available from August 2019 I believe. I get 50km far at the moment with mine.
#2 was an option
#3 was an option
#4 was an option
#5 I don't believe you get an E plate for your battery size but I could be mistaken. I have the 10kw battery and was able to get the E plate.
#6 not sure about that one
Ich habe einen BMW 225xe Bj 2018 und habe den bisher nur an der Steckdose aufgeladen. Nun habe ich eine Wallbox (Pulsar pro) bekommen - doch leider meldet die, das Fahrzeug muss "Ladevorgang anfordern". Wie mir der Elekromeister erklärt, muss der BMW ein entsprechendes software Programm erhalten., damit er die Wallbox erkennt bzw. über diese lädt. Weiß jemand, wie das funktioniert, was das kostet bei BMW bzw. ob man das selber vornehmen kann?
Danke im voraus
Hallo, das hört sich sehr komisch an.
Eine private Wallbox verhält sich für den Wagen genau wie eine öffentliche.
Kannst Du öffentlich laden?
Nach der Montage meiner Wallbox ging auch erstmal nichts, nach genauer Prüfung durch den Elektriker wurde ein Fehler beim Anschluss der Wallbox gefunden, ein Kabel war nicht richtig abisoliert und hatte somit keinen Kontakt.
Für mich liegt der Fehler bei Dir an der Wallbox.
Guck mal bitte im Auto ob du auf direkt laden umgestellt hast.
Habe ich noch nie gehört......
Kann ich mich nicht vorstellen das das am Auto liegt.
Jeder Elektrofirma die sich mit Wallboxen auskennt hat einen Prüfgerät das am Wallbox zwecks Test angeschlossen wird bei Inbetriebnahme.
danke für eure Antworten. Hab naechste Woche einen Termin bei BMW - die wollen ein update draufspielen, dann ging s...mal sehen
Da bin ich selbst schon reingefallen
Lade ohne Probleme mit dem go-eCharger V3
